motofan
Nov 25, 2021Follower
static connection setup D6400 modem to router AX5400
My internet led goes red every couple of days but I still have internet. If I turn off and restart the router it goes back to normal. May be I have setup the static address wrong. can anybody help me...
Nov 26, 2021Guru - Experienced User
Be sure to check your modem for good signal from the ISP service.
I recommend bridging the D series modem since it already has a built in router. Having two routers on the same line can cause problems.
For RAX model support and information, Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
