Steven1256
Jul 17, 2023Aspirant
static ip for printer
I have the nighthawk wifi 6 (ax) router and am looking for assistance in setting up a static IP for a printer. Am not sure where to put it in the router. Am thinking in Advanced Setup, static Routes....
- Jul 18, 2023
Just so you know, Static IPs are set ON devices, not the router. IP address reservations are set ON the router.
Steven1256
Sorry, it's an AX6 AX5400 6-stream router: Firmware Version V1.0.12.120_2.0.83
schumaku
Jul 17, 2023Guru - Experienced User
RAX50 is the key for the model.
RAX50 — Nighthawk AX6 6-Stream AX5400 WiFi 6 Router In the Documentation Section https://www.netgear.com/support/product/rax50#docs you find the Nighthawk AX6 6-Stream AX5400 WiFi Router Models RAX50 and RAX50v2 User Manual, on p.50 there is a chapter on "Manage reserved LAN IP addresses".
- Steven1256Jul 17, 2023Aspirant
I did what you suggested however, the info was already there and I didn't do anything except open the menu. Here's a screen grab:
- michaelkenwardJul 18, 2023Guru - Experienced User
Maybe it is working. Do you have a problem with the printer?
- Steven1256Jul 18, 2023Aspirant
The IP address kept changing every few days!
