Steven1256
Jul 17, 2023Aspirant
static ip for printer
I have the nighthawk wifi 6 (ax) router and am looking for assistance in setting up a static IP for a printer. Am not sure where to put it in the router. Am thinking in Advanced Setup, static Routes....
- Jul 18, 2023
Just so you know, Static IPs are set ON devices, not the router. IP address reservations are set ON the router.
Jul 18, 2023Guru - Experienced User
Something I do with my printers, Set a static IP address on the printers, something that's out of range of my routers default DHCP IP address pool. Let the printer handle the IP address then it never changes and you know where it's at. Most printer don't need any router management anyways.
Steven1256 wrote:
The IP address kept changing every few days!
Steven1256
Jul 18, 2023Aspirant
FURRYe38 wrote:Something I do with my printers, Set a static IP address on the printers, something that's out of range of my routers default DHCP IP address pool. Let the printer handle the IP address then it never changes and you know where it's at. Most printer don't need any router management anyways.
Steven1256 wrote:The IP address kept changing every few days!
Thanks Furry, I did just that. So far it's staying put. Thank you for the assist. Set it up as a static ip in the router so the dhcp doesn't re assign it.
- FURRYe38Jul 18, 2023Guru - Experienced User
