FiddleFart
Nov 11, 2021Aspirant
static line
Im having problems with my camera's What's happenning is the camera's will work for a bit, then won't work at all, then after a day or two, they will work then back off. Is it possible to have one ...
Nov 11, 2021Guru - Experienced User
You can set IP Address Reservations on the router for connected devices.
FiddleFart
Ive did set the cameras to a permant address.
Ive done that but it sends the cameras to the
"view list of allowed devices but not connected to the network"
Ive checked all of the connections between the nvr and router.
Ive reset my router.
Ive reset the nvr.
- FURRYe38Nov 11, 2021Guru - Experienced User
Can you use the Choose File button and attach a screen shot of what your seeing on the router?
What browser are you using?
- FiddleFartNov 21, 2021Aspirant
Sorry it took so long to get nack to you, but I found the problem...
I was using a flat cat 4 ethertnet cable and I foung a small tear in the cable...
switched it out with a cat8 heavy duty cable and everyting is working great now!
Thanks for you time and effort!
