Covington5000
May 22, 2021Aspirant
Step by step instructions on adding a Orbi mesh system to a Netgear Ax12 RX120 router
 I bought a Orbi Mesh wifi 6. I have a Netgear Ax12 RX120 router. I wanted to run the mesh system as a back up router. Can I do that? and is there a guide somewhere as to how to do it?
May 22, 2021Guru - Experienced User
You can go:
modem---->RAX120 (router mode)------>Orbi system (access point mode)
I've done this numerous times and its pretty easily setup. You'd simply put the orbi in access point mode and connect the orbi router to the RAX.
- michaelkenwardMay 23, 2021Guru - Experienced User
 plemans wrote:
 I've done this numerous times and its pretty easily setup. Same here. Works perfectly.
- Covington5000May 23, 2021AspirantOne more question, will the other two satellite stations also act as access points when I change the router to access mode? - michaelkenwardMay 23, 2021Guru - Experienced User
 Covington5000 wrote:
 ....will the other two satellite stations also act as access points when I change the router to access mode? Yes.
