Covington5000
May 22, 2021Aspirant
Step by step instructions on adding a Orbi mesh system to a Netgear Ax12 RX120 router
 I bought a Orbi Mesh wifi 6. I have a Netgear Ax12 RX120 router. I wanted to run the mesh system as a back up router. Can I do that? and is there a guide somewhere as to how to do it?
Covington5000
May 23, 2021Aspirant
One more question, will the other two satellite stations also act as access points when I change the router to access mode?
michaelkenward
May 23, 2021Guru - Experienced User
Covington5000 wrote:
....will the other two satellite stations also act as access points when I change the router to access mode?
Yes.
