Johjohjus
May 28, 2021Follower
Still need a modem? Ax4300
Do I still need a modem to work with this ax4300?
antinode
May 28, 2021Guru
What is your "this ax4300"? "AX4300" is a speed, not a model number.
Look for "Model" on the product label. RAX45?
With that datum in hand, you might try a radical concept which works
for some people:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
"still"? Did you need a modem before? With some other (unspecified)
router? The non-psychics in your audience might know very little about
your Internet service, or what your (unspecified) ISP might require, or
what you were using before, with what.
A RAX45 is a router, with no built-in modem. If your service
requires a modem, then I'd expect your service with a RAX45 to require a
modem, too.
