Johjohjus
May 28, 2021Follower
Still need a modem? Ax4300
Do I still need a modem to work with this ax4300?
michaelkenward
May 29, 2021Guru - Experienced User
How do you get the Internet?
If you have an Internet service provider that fixes some sort of box to the wall, that may be able to feed a router. But that is usually "fibre to the home" Internet.
A good place to ask the question is with the ISP that sells you the Internet service.
