df2ef2f2f23f2ef's avatar
Jul 02, 2022
Still no new firmware for RAX200 to fix 1.0.6.138_1.0.76?
It's been almost 3 months, still don't see a new version of firmware to fix 1.0.6.138_1.0.76? So many people reported issues, is Netgear still denying it???? The DNS has issues when VPN is used!
Netgear is the worst router brand I have had so far... should have stayed with Asus... wasted 600 dollars on this.....
1 Reply
  • FURRYe38's avatar
    Has a factory reset and setup from scratch been performed since you updated?
    What region are you located? $600? Brand new?
    How long have you had it?
    NG is aware of this and is working on it.
    Try using prior working version of FW?
