b0redj0rd
Apr 19, 2023Tutor
Strange behaviour: WiFi/internet RAX200
Internet/WiFi behaving very strange. RAX200 Hey guys. I'm seeing some strange behaviour on my WiFi at the moment and I'm trying to figure out what is happening. I have an RAX200 connected to Sk...
b0redj0rd
Apr 20, 2023Tutor
Hey there Furry, thanks for taking the time to reply here.
Okay, so the situation is thus - I have done a complete factory reboot of the RAX200, and the extender (however I have not set the extender up and it is switched off). I have FTTP from SKY in the UK, and so am connecting directly to the RAX200 using 'Option 61' so there is no modem involved, the firmware is up to date according to the set up process on the router.
I have changed the channels are advised, and I am now able to have a teams call with a colleague, which is great however I am STILL unable to open or browse the internet and basically do anything else at all. When I do the internal speed test on the router via the Nighthawk app, interestingly enough I am ONLY getting speeds back for the upload - I get 0 for the download. To further confuse the issue, when I try to go to a speed testing website using WIFI on my phone (connected to the RAX) it will NOT connect and run.
To further troubleshoot, I have connected the laptop which has issues via ethernet to the RAX200 and I see the same problems.
Now, I have the original SKY Hub here, which I have set back up to see if this is an issue with the line or the router and to my surprise everything is working absolutely fine - I am replying to this thread on the computer which wasn't able to browse the internet using the RAX200. I think that some protocols or ports or etc are being blocked by the RAX200, because even the speed test app is WORKING on my phone when connected via the Sky Hub (WiFi)
Last night (and for the last few days since I have seen issues) on the NVIDIA Shield I have not been able to see any Real Debrid links for streaming content. Now, with the Sky Hub connected I am able to see these links.
Has anything like this happened before? Obviously, nothing changed on the settings the RAX200 as far as something I have changed. Looking around the access control area on the router no devices have any 'blocks' against them or anything like that. The RAX200 is 100% blocking traffic or protocols somewhere along the way.
Could this be a fault with the router itself?
Apr 20, 2023Guru - Experienced User
I would leave the Sky router connected and then connect the RAX router to the Sky router. Remove any ISP configurations from the RAX router. Just use DHCP for the WAN connection on the RAX router. Use the Sky routers DMZ for the IP address the RAX router gets from the Sky router. Disable ALL wifi radios on the Sky router. Observe you findings using this configuration on the RAX router.
- b0redj0rdApr 20, 2023Tutor
Hi again Furry,
Thanks again for your reply. I have something else to report ... I am a little reluctant to connect the Hub to the RAX as I was seeing a double NAT the last time I did this - Sky don't allow a bridge mode on their router. Would the set up you describe cause this? Either way, currently the Sky router is connecting fine with the extender so I am able to get the desired result - A good home office connection.
As I mentioned I was hesitant to make the change, but I thought I'd try to add the Sky DNS addresses to the RAX and see if this corrected the issue and so rebooted the RAX, refreshed the connection for fibre and have booted up the laptop that wouldn't connect to the internet ... everything is working. It seems that after having the hub connected for a few hours, whatever the issue was is resolved.
Do you have any idea what it could be?! I'm totally confused here and unsure if the best course of action would be to leave things as they are (RAX only) or whether to simply have the hub pushing out to the extender for fear that this will inevitably happen again at some point in the future.
- FURRYe38Apr 20, 2023Guru - Experienced User
The DMZ on the SKY router solves the double NAT issue with the RAX in this configuration.
I would also try the RAX in AP mode connected to the SKY router as well. No DMZ needed for this mode.Possible that the ISP DNS is not getting to the RAX from the ONT when the SKY Router is not connected. Try the RAX back has main host router with DNS changes and ISP configuration with the ONT only and see...
