nhnative
Aug 31, 2019Aspirant
Sudden loss of 5G1 and 5G2
PC running Windows 10 64 Bit. Updated to the latest firmware version. Shut PC down one night and everything was fine. When I started the following morning 5G1 and 5G2 were missing. Spoke to provi...
- Sep 07, 2019I like smart connect as it does band steering but some prefer their bands separated out. Glad to hear it fixed the problem. If you mark the answer as solved it'll help out the next person with this problem
nhnative
Sep 07, 2019Aspirant
I turned off Smart Connect and they came back as you said. Thank you very much for you help.
Sep 07, 2019Guru - Experienced User
