Rodney007xx
Nov 06, 2021Aspirant
Sudden loss of WiFi, what is Bernie?
I have recently purchased a Nighthawk AX4200 modem. I had run the setup wizard and the internet/Wifi was works fine. Then for no reason at all, after 2 weeks the wifi drops off, and the connection ...
- Dec 09, 2021
Hello Los
Make sure you are on the latest firmware as a fix was released for this issue.
Thanks
DarrenM
Nov 07, 2021Guru - Experienced User
What actual modem/router do you have? AX4200 is a speed and the RAX40 you put in your signature isn't a modem.
Are you leaving your wifi network open?
Are you changing your login info to the router?
Just curious as "Bernie" isn't a standard naming so I'm wondering if someone is getting access to your setup and changing the ssid/password.
Rodney007xx
Nov 07, 2021Aspirant
Hi,
The modem is setup for my parents house. There is no other house nearby.. and "Bernie" has full bars WiFi signal. So ita coming from the modem, and after the second time I left the "NETGEAR18" SSID in place...thats gone and replaced by Bernie.
I googled it an others have also experienced this problem. Apparently "Bernie" is a Netgear Wifi SSID from the factory??
