Rodney007xx
Nov 06, 2021Aspirant
Sudden loss of WiFi, what is Bernie?
I have recently purchased a Nighthawk AX4200 modem. I had run the setup wizard and the internet/Wifi was works fine. Then for no reason at all, after 2 weeks the wifi drops off, and the connection ...
- Dec 09, 2021
Hello Los
Make sure you are on the latest firmware as a fix was released for this issue.
Thanks
DarrenM
julieginger
Nov 22, 2021Aspirant
I have a RAX50 and have been having this problem on and off since I purchased it, like I had it maybe 5 days then this started intermittently. The router randomly renames itself Bernie_RAX50 and that is not the default name of my device. I do have my router very locked down as far as security for both primary and guest network with nothing left open. I have to do a factory reset and rebuild my network each time. This is the most garbage POS I have ever encountered and a MAJOR FLAW which Must be in the firmware or there wouldnt be so many people with the same exact problem where it resets to the same SSID name. I have seen many people across the world comment this issue now (found under a Google search). Were I not a IT Sys Admin for over 20 years, and just a novice home user I would be at my wits end! HORRIBLE of Netgear, HORRIBLE!!!!! Such an expensive device which has inherenent flaws out of the box.
- Rodney007xxNov 23, 2021Aspirant
Yes its very fustrating, lukcily the support through the app is good and instant, however the worrying issue is most staff/workers at NETGEAR have no idea what the fault is even when they ask supervisors. It took me 3 attempts on the chat support for someone to guide me through changing some settings, even then it was "lets try this" its been 2 weeks and has not happened so fingers crossed.
Another mod above said he has a firmware patch to fix the issue.
I saved all the chat transcripts as if the issue arrises again I am 100% taking it back for a refund.
I am happy to share the chat dialog with the instructions of how we fixed mine if that helps?
