Rodney007xx
Nov 06, 2021Aspirant
Sudden loss of WiFi, what is Bernie?
I have recently purchased a Nighthawk AX4200 modem. I had run the setup wizard and the internet/Wifi was works fine. Then for no reason at all, after 2 weeks the wifi drops off, and the connection ...
- Dec 09, 2021
Hello Los
Make sure you are on the latest firmware as a fix was released for this issue.
Thanks
DarrenM
julieginger
Nov 22, 2021Aspirant
I have a RAX50 and have been having this problem on and off since I purchased it, like I had it maybe 5 days then this started intermittently. The router randomly renames itself Bernie_RAX50 and that is not the default name of my device. I do have my router very locked down as far as security for both primary and guest network with nothing left open. I have to do a factory reset and rebuild my network each time. This is the most garbage POS I have ever encountered and a MAJOR FLAW which Must be in the firmware or there wouldnt be so many people with the same exact problem where it resets to the same SSID name. I have seen many people across the world comment this issue now (found under a Google search). Were I not a IT Sys Admin for over 20 years, and just a novice home user I would be at my wits end! HORRIBLE of Netgear, HORRIBLE!!!!! Such an expensive device which has inherenent flaws out of the box.
Rodney007xx
Nov 23, 2021Aspirant
Yes its very fustrating, lukcily the support through the app is good and instant, however the worrying issue is most staff/workers at NETGEAR have no idea what the fault is even when they ask supervisors. It took me 3 attempts on the chat support for someone to guide me through changing some settings, even then it was "lets try this" its been 2 weeks and has not happened so fingers crossed.
Another mod above said he has a firmware patch to fix the issue.
I saved all the chat transcripts as if the issue arrises again I am 100% taking it back for a refund.
I am happy to share the chat dialog with the instructions of how we fixed mine if that helps?
