chenrysjr
Nov 07, 2021Follower
Support Radius
Hi,
Does the NETGEAR Nighthawk 12-Stream AX12 Wifi 6 Router RAX200 support the use of a Radius server and WPA2-Enterprise?
Thank you,
Henry
1 Reply
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6Review the user manual for these features. IF you don't see this information, then mostly they don't. Most Radius is usualy at the Business or Enterprises level and not seen in Home environments.
Thank you.
