rekastens
Nov 08, 2021Aspirant
Surfshark VPN with R6400v2
I have a Nighthawk R6400v2. I would like to download Surfshark VPN and put it on the router. Surfshark says I should look for OpenVPN Client in the list and not to mix it up with an OpenVPN server. D...
Nov 09, 2021Guru - Experienced User
Netgear has set up a community forum specifically for General Router products. Most of the people who watch that forum are more likely to have experience with older routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you
rekastens wrote:
I have a Nighthawk R6400v2. I would like to download Surfshark VPN and put it on the router. Surfshark says I should look for OpenVPN Client in the list and not to mix it up with an OpenVPN server. Does anyone know if R6400v2 has OpenVPN Client? I cannot seem to find that this is compatible with R6400v2. Does anyone know if I can download and use Surfshark on R6400v2?
Thanks,
Ron
