pjd813
Aug 05, 2022Guide
Swap from RAX120 to R8000 doesn’t recognize HO laptop now
I purchased an RX120 to replace my R8000 and the RAX120 simply doesn’t work. I’m returning it so when I connected the R8000 back up EVERY Apple product, thermostat, server, doorbell camera, and ROKU ...
Aug 05, 2022Guru - Experienced User
Are you sure the laptop is connected to the router? Wireless or wired?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Is IPv6 enabled on the R8000 router?
pjd813
Aug 05, 2022Guide
The only variable here is the RAX120 vs. the R8000. The R8000 and the HP worked together before I tried the RAX120 and all I did this morning was swap the RAX120 out and re-attach the R8000. As noted 10 to 15 wired and wireless devices from different companies throughout the house just popped up and resumed working reconnected to the R8000 as if nothing had changed. At least the RAX120 sort of works for basic connectivity to the HP. The RAX120 connection to the internet is very wonky and that’s why I’m trying to return it, but the R8000 needs to be my bridge between the RAX120 and whatever replaces it. I have put the RAX120 back in the mix because the HP must work. It just must. I’m not going to muck up life with more troubleshooting until Monday. My CM500 modem has no bearing here since again all other devices receive and transmit to the internet with no problem. All devices, as well as the HP laptop are current with updates. Everything has been turned off/on, connected/disconnected, and connected wired and wireless, etc. The HP simply won’t connect to the internet wirelessly even though the router and the HP can “see” each other. The HP must also be untethered and wireless and cannot be in a fixed position via Ethernet. The HP shows in the wirelessly connected devices list when connected to the R8000 but there is no IP Address shown in the table.
