thebditch
Apr 28, 2021Aspirant
Swapping from XFinity XFi to CM2050V / RAX200 drops my speed tests from 400+ to 100 ish
Hi, I have just swapped today from a XFinity XFi modem/router to a CM2050V / RAX200 combo. I did tests with several speed apps (inc FCC) and sites and consistently got over 400 Mbps. After the i...
thebditch
Apr 29, 2021Aspirant
Hi,
Thanks for responding so fast
what speed do you get hardwired into the router?
I will test that speed later today as I am working; I have an Xfinity gigabit connection and was testing near that before the swap
what device are you testing on wireless?
two devices:HP Elite Book i7 Windows 10 and Samsung S20 Ultra
are you using the speedtest app on mobile?
FCC, NightHawk and Xfinity apps, plus several website inc https://whatismyipaddress.com/speed-test
how far from the router are you for testing.
In office less that 40 feet from router
What firmware are you on?
V1.0.3.106_1.0.58
Are you using smart connect?
Yes
Only one other person in house who does stream TV but not present and I am still only getting 200
Thanks
Trevor
Apr 29, 2021Guru - Experienced User
Make sure to test hardwired into the router and hardwired into the modem.
to many variables impact wireless speeds so lets start at basics and ensure full speeds at the modem and then at the router.
- thebditchApr 29, 2021Aspirant
Thanks, will do,
I ma getting a slower speed hardwired also only just above wireless speeds - not what I expected.
I checked the pings and tracert and see the response times to the Xfinity gateway and DNS is slow (see piong and tracert stats below)
I will check with Xfinity as this is meant to be a gigabit connection.
ping 192.168.1.25 (local NAS)
Ping statistics for 192.168.1.25:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 8ms, Average = 3msC:\WINDOWS\system32>ping Xfinity Gateway IP
Ping statistics for Xfinity Gateway IP:
Minimum = 10ms, Maximum = 12ms, Average = 11msC:\WINDOWS\system32>tracert Xfinity Gateway IP
Tracing route to Xfinity Gateway IP over a maximum of 30 hops
1 2 ms 1 ms 1 ms 192.168.1.1
2 11 ms 10 ms 13 ms Xfinity Gateway IPTrace complete.
C:\WINDOWS\system32>tracert 75.75.75.75 (Xfinity DNS server)
Tracing route to cdns01.comcast.net [75.75.75.75]
over a maximum of 30 hops:1 2 ms 1 ms 1 ms 192.168.1.1
2 13 ms 11 ms 19 ms xx.xx.xx.xx
3 14 ms 13 ms 12 ms 24.153.94.197
4 11 ms 10 ms 12 ms 162.151.39.237
5 13 ms 11 ms 12 ms 24.124.175.21
6 13 ms 11 ms 12 ms 68.87.170.14
7 13 ms 16 ms 12 ms dns-sw02.sandy.ut.utah.comcast.net [68.87.170.30]
8 10 ms 10 ms 16 ms cdns01.comcast.net [75.75.75.75]Trace complete.
C:\WINDOWS\system32>ping 8.8.8.8 (google)
Ping statistics for 8.8.8.8:
Minimum = 23ms, Maximum = 28ms, Average = 24ms- thebditchMay 24, 2021Aspirant
I had an Xfinity engineer come out and test the spped which was up to par 800-1100 and using a Cat 6 connection to the Modem has good spped, but unless I am right next to the router I do not get more that 300 at best and mostly 100.
I guest it is just my house - anyhow 100 is good enough as I had move the route into my office and hardwired my office PC for work.
Thanks all.
