thebditch
Apr 28, 2021Aspirant
Swapping from XFinity XFi to CM2050V / RAX200 drops my speed tests from 400+ to 100 ish
Hi, I have just swapped today from a XFinity XFi modem/router to a CM2050V / RAX200 combo. I did tests with several speed apps (inc FCC) and sites and consistently got over 400 Mbps. After the i...
thebditch
Apr 29, 2021Aspirant
Thanks, will do,
I ma getting a slower speed hardwired also only just above wireless speeds - not what I expected.
I checked the pings and tracert and see the response times to the Xfinity gateway and DNS is slow (see piong and tracert stats below)
I will check with Xfinity as this is meant to be a gigabit connection.
ping 192.168.1.25 (local NAS)
Ping statistics for 192.168.1.25:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 8ms, Average = 3ms
C:\WINDOWS\system32>ping Xfinity Gateway IP
Ping statistics for Xfinity Gateway IP:
Minimum = 10ms, Maximum = 12ms, Average = 11ms
C:\WINDOWS\system32>tracert Xfinity Gateway IP
Tracing route to Xfinity Gateway IP over a maximum of 30 hops
1 2 ms 1 ms 1 ms 192.168.1.1
2 11 ms 10 ms 13 ms Xfinity Gateway IP
Trace complete.
C:\WINDOWS\system32>tracert 75.75.75.75 (Xfinity DNS server)
Tracing route to cdns01.comcast.net [75.75.75.75]
over a maximum of 30 hops:
2 13 ms 11 ms 19 ms xx.xx.xx.xx
3 14 ms 13 ms 12 ms 24.153.94.197
4 11 ms 10 ms 12 ms 162.151.39.237
5 13 ms 11 ms 12 ms 24.124.175.21
6 13 ms 11 ms 12 ms 68.87.170.14
7 13 ms 16 ms 12 ms dns-sw02.sandy.ut.utah.comcast.net [68.87.170.30]
8 10 ms 10 ms 16 ms cdns01.comcast.net [75.75.75.75]
Trace complete.
C:\WINDOWS\system32>ping 8.8.8.8 (google)
Ping statistics for 8.8.8.8:
Minimum = 23ms, Maximum = 28ms, Average = 24ms
thebditch
May 24, 2021Aspirant
I had an Xfinity engineer come out and test the spped which was up to par 800-1100 and using a Cat 6 connection to the Modem has good spped, but unless I am right next to the router I do not get more that 300 at best and mostly 100.
I guest it is just my house - anyhow 100 is good enough as I had move the route into my office and hardwired my office PC for work.
Thanks all.
