GexBox
Sep 24, 2023Aspirant
Switch limiting to 100Mbps
Hi,
I bought my router a few years ago, I've used it in several places in the house. However only today did I actually check the download speed through the switch. From my PC I can connect directly...
michaelkenward
Sep 24, 2023Guru - Experienced User
GexBox wrote:
The RSD120 is connected directly to the internet box.
What's the RSD120 ? What's the Internet box?
I don't use the "wan" connector on the RAX120 - router mode.
That connection usually goes to whatever connects you to the Internet.
