dave9398
May 10, 2023Aspirant
Switching from PPPoE to IPOE (DHCP)
Hello, I currently have CenturyLink Fiber and configured my RAX 50 to use it as my home router. I have been informed by CL that they are rebranding/splitting off their fiber unit and the new name wi...
dave9398
Thanks for the replies, I guess my main concerns is that my Nighthawk router does not appear to have the option to indicate that the connection should use DHCP. It currently only offers PPPoE, PPTP, and L2TP. Does clicking on no for required authorization automatically indicate that the router should accept a dynamic address? Also if there is anyone who has been through this migration and kept their same router, it would be great to hear from you.
Dave
May 10, 2023Guru - Experienced User
Default mode for all NG routers is DHCP.
There will be a DHCP option seen under Internet Setup. There maybe two options seen here, DCHP and PPPoE selectable radio dots or buttons.
- dave9398May 10, 2023Aspirant
This is what my router's internet setup options page looks like, there is no DHCP, it is a dropdown not a radio button option.
- FURRYe38May 10, 2023Guru - Experienced User
OK, I forgot that the options are YES and NO. Yes means it changes to PPPoE configuration. NO, changes back to DCHP.
