Anquietas
Mar 09, 2024Aspirant
Switching from PPPoE to IPOE
When switching from PPPoE to IPOE/DHCP, does the netgear allow to still do the vlan tagging? Quantum support/and the router they setup for me, has IPOE with vlan 201, however they did also give me IP...
Anquietas
Mar 10, 2024Aspirant
Currently have Linksys Velop, so looking for a replacement now. Prefer mesh with 3+ Ethernet ports each
michaelkenward
Mar 11, 2024Guru - Experienced User
You want help to pick a new router?
(We aren't mind readers.)
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
- AnquietasMar 11, 2024AspirantIPOE or DHCP with vlan tagging isn’t something normally listed under product features.
The sales concierge/chat team also isn’t familiar and suggested reaching out to the community.- michaelkenwardMar 11, 2024Guru - Experienced User
Anquietas wrote:
IPOE or DHCP with vlan tagging isn’t something normally listed under product features.Of the 1440 documents from Netgear on my system only one mentions IPOE. That's the Data Sheet for the D2200D ADSL Gateway from 2014.
285, overwhelmingly modems and modem/routers, mention PPPoE.
I wonder about the basic question.
Once again, we have incomplete information.
What is this router Quantum setup for you? Maybe it is a modem or modem/router.
current setup: Centurylink (Fiber) Casa ONT -> C4000BZ -> Linksys Velop (bridge mode)
before CL switched from PPPoE to IPOE I was using ONT -> Velop with no issues. (PPPoE on the velop)
- I'm not finding any mesh networks that list IPOE as a WAN connection type. DHCP is normally the solution, however CL/Quantum/Lumen require the VLAN tag in most regions. (DHCP with VLAN tagging is not a common feature)
needs:
Mesh - preferably with 3+ ethernet ports on each node
IPOE connection type (username, password, VLAN in my case 201) [PPPoE using same information does not work, and DHCP/auto does not work)
