progmanjum's avatar
progmanjum
Switching to RAX43 in new house.
Currently have AC1900 I believe. Moving into a new house with a new RAX43. Can I have them both set up with same ID and password so that we have one in both houses as we move? New house will have mod...
  • michaelkenward's avatar
    michaelkenward
    Jul 27, 2024
    progmanjum wrote:
    So I can/should be able to transfer the settings from R7000 to RAX43 and use them in seperate houses for about a month, if I understand correctly?
    You cannot transfer the settings.That is beyond the capabilities of Netgear's routers and is high on the wishlist for many people.
    You can set up the new router with the same settings for wifi and admin access.
    And there is nothing to prevent you from using the same details in two locations. I do this all the time because I have two separate networks, home and office.
