cyberwasp
Oct 03, 2021Star
Synology NAS Pihole
Is anyone out there running a Netgear Nighthawk rax50 connected to a synology disk station running Pihole. After replacing the first RAX50, This one lets me Change The DNS server to point to the NAS....
Razor512
Oct 03, 2021Prodigy
Make sure your client devices are getting their DNS settings from the DHCP server in the router. Also if you have software such as PIA or other commercian VPN servers installed, they will often override your DNS settings even for non-VPN traffic.
Furthermore, the pi-hole does not work on ads that are loaded via obfuscated scripts. For example, many sites will try to get arond DNS filters by using randomly generated domain names.
If you look as many of the pages with obnoxious ads, you will notice that a trend now is to see a first party provided script using XHR which will load obnoxious ads from a random domain. Since part of the content is from the first party, you can't block the domain, and since the script uses some kind of time based script that periodically uses a different domain, pi-home can't keep up with it it.
In those cases, your only hope is to use browser based ad blocking such as ublock origin.
Beyond that, routers will also cache DNS info.
Also be sure to check if the pihole is properly weorking. In windows, set the pihole as the primary and secondary DNS, and then see if it blocks some of the known ad domains.
Razor512
Oct 03, 2021Prodigy
Sorry for the typos, the site lacks an edit button.
Beyond that, to be clear, a pi-hole will fail to block most modern ads, especially from recent months where many sites have been trying to circumvent DNS based ad blocking.
If possible look at the filters the pi-hole is using and then in your browser, attempt to load something from one of those domains that you have not visited before. Also check if it offers any logs on what it blocked
Beyond that, consider using ublock origin on your browser.
- cyberwaspOct 03, 2021Star
Razor512 Actually Pihole isn't my problem. It's getting the DNS Server setting to take hold. I put it in like the attachment shows and save it. However it didn't work. I think I stumble on it by mistake. You have to set the router MAC Adress to, "Use This MAC Address." something I never had to do with my other router. Is this correct and if not, why is it working!! And again, Thank you!!!!!!!!
- Razor512Oct 05, 2021Prodigy
That is quite strange, especially considering that it is a function largely for some cable modems and ONTs that have restrictions such as if you change a router without first releasing the DHCP lease, they will not assign a new IP if the MAC address has also changed.
