So_tired
Jul 24, 2025Guide
TCP SYN Flooding on RAX54v2 Router, Please help!
Hello all, i REALLY need help with stopping massive TCP SYN Floods to my home router. What has happened thus far: I got this router about 2 months ago ,(upgrading from a very old TP-link whic...
- Aug 06, 2025
OK so updated my RAX50v2 to recent FW version.
Factory reset and setup from scratch.CAX80 in modem mode.
PE is enabled by default. Testing with it enabled and disabled:
PE Enabled:
PE Disabled:
I Noticed that the testing site was being reported as flooding the logs:
[admin login] from source 192.168.1.2, Wednesday, Aug 06, 2025 15:39:37
[admin login] from source 192.168.1.2, Wednesday, Aug 06, 2025 15:39:33
[DoS attack: TCP SYN Flood] from source 4.79.142.206,port 45743 Wednesday, Aug 06, 2025 15:39:03After I logged in at 15:39 and disabled PE and re-tested again after that, logs didn't report any flooding from the test site.
I recommend that after you disable PE and re-test, have your ISP give you a new WAN IP address as I presume some nefarious items may have a target for that WAN IP address. Once you have PE disabled and a new WAN IP address, I'm hoping you shouldn't see issues continue.
Jul 31, 2025Guru - Experienced User
Have you done a whois look up on that IP address to see where it maybe coming from?
Do you see Protection Engine feature on the routers web page at all? Under Advanced Tab/Security?
So_tired
Aug 01, 2025Guide
I ended up going to best buy and getting a Netgear Nighthawk CM2500 mid/high split.
Set it up.
Getting stupid fast speeds, no drops BUT I am STILL getting "TCP SYN flood" s -_-
At least now when it happens it barely blips my internet. The floods only happen on large numbered ports now it seems...
From 3000-6000+ ports.
I also un plugged everything for hours today and re-plugged everything in. Got a new IP (still local...) so that did not work, again lol
I ran ShieldsUP! Again and it said all of my major ports are stealthed but ALL of the other ports (except 0-127,135-139, and 445) are not, they are all closed. Ill show a pic.
At this point, should I even worry if they are only flooding the big ports? Am i in any danger?
Still no way to stop this?
