madcity
Dec 11, 2020Aspirant
Telnet on R6700AX
Hi... I just got this unit. I am moving to Japan (and will have an apartment in Korea), but want to set it up/test/use before I leave. So I need to be able to change the Region to "worldwide" to test the appropriate WIFI channels depending which country I use this in.
Open 10.0.0.xxx - "Could not open connection to the host, on port 23: Connect failed"
I've looked at the "debug" page for V1.0.1.80 - no option to enable Telnet
I dropped back to the earliest firmware (V1.0.1.78) - still no option to enable Telnet
I've tried telnetenable2 - didn't work
I've tried NTE, which also didn't work - C:\nte m=9CC9EBxxxxxx n=10.0.0.xxx u=xxx p=xxx [debug]
debug: 0xffffffff .
MAC0: >9CC9EBxxxxxx<.
MAC1: >9CC9EBxxxxxx<.
user: >xxx<.
pass: >xxx<.
getaddrinfo():
ai_family = 2, ai_socktype = 0, ai_protocol = 17
ai_addrlen = 16, ai_addr->sa_family = 2.
ai_flags = 0x00000004.
ai_addr->sa_data[ 2: 5] = 10.0.0.xxx
dns_resolve() sts = 0.
sock = 260, FD_SETSIZE = 64,
FD_ISSET( sock, &fds_rec) = 1.
pre-select(1). sock = 260.
select(1) sts = 0.
nte: FAIL. No ACK message received.
Any other ideas either to telnet in or other method to enable the region setting?
Tagging antinode & Steve_AES as you both seem to be engaged on this topic in other threads.
Thanks in advance.
- Steve_AESAspirant
had no luck getting my R8000 wireless region unlocked so bought a mesh setup
- madcityAspirant
I should also mention that I am 100% I am using the LAN MAC ID in my NTE Command Line. Here is some addtional information from some Hidden Pages:
Board Model ID : RAX1xseries FW Version : V1.0.1.80 Again, any help to set to Worldwide greatly appreciated.
