aonavy1
Sep 09, 2019Guide
Terrible AX wifi speeds (ax12) with AX200 laptop
1st off, I'm a 10 year systems admin, I have some knowledge here (not being cocky) Laptop- Zenbook Duo Pro (ax200) RAX120 router XS505M 10Gbe switch Z230 i7 16gb with Asus 10gbe network card a...
abogrhen
Sep 17, 2019Guide
for me i am having a different problem
the speed is good
but after 2 hours the actual net speed drop from 100 mb to 15mb or lower
and resetting either the wifi card or router solve it for 2 hours then i have to repeat again
- Christian_RSep 17, 2019NETGEAR Employee Retired
abogrhen,
Please try disabling the smart connect feature if you have it enabled.
Christian
- aonavy1Sep 17, 2019GuideIt's never been on. I did however get some decent speeds (175MBs) changing the channel to 100 using HT160. I think should be closer to 200-225MBs while connected to 2.4ghz but this work until another firmware comesabout.
- abogrhenSep 17, 2019Guide
yeah i think there is a communication problem between rax120 and ax200
i hope both sides Intel - Netgear can look into it
