michail71
Jul 21, 2020Apprentice
Terrible WiFi with RAX12 after switching off Xfinity AP
I deciced to replace the AP on my Comcast XB6 with the RAX120. Everything went great at first! I was hitting 870+ Mbps on WiFi 6 and 600-700 on 802.11 AC devices. Latency was low and legacy device...
worldturning
Jul 25, 2020Star
michail71 wrote:How did you get bridge mode working? I tried twice and the XB6 and RAX don't seem to negotiate the settings.
Although, at this point I don't trust the RAX to be using it as a router and the only AP. I'm keeping an SSID open on the XB6 as an emergency fallback.
I just logged into the XB6 and enabled Bridge Mode. Even after it enabled, I rebooted the XB6 again to make sure it stayed in Bridge Mode.
Note that you can't have another device connected to the 2nd XB6 network jack or you won't get an internet connection on the router (RAX120). It will "confuse" the XB6 to have 2 devices requiring an ip address after bridge mode is enabled. It makes sense to me now, but at the time, it was frustrating.
I made the mistake of having both the RAX120 (jack #1) and a laptop (jack #2) plugged into the network jacks of the XB6. I was using the laptop wired directly to the XB6 to enable bridge mode. I kept ending up with the red light (no internet connection) on the RAX120. I even did a couple of resets of the RAX120 and still no go. Finally found the answer on the xFinity forum. You may also need to have the router connected to jack #1 (instead of jack #2) on the XB6.
I'm using the RAX120 in a home with 3 floors of concrete block and doesn't have the ethernet or coax wiring to each floor so I was looking for a router with range and also curious about WiFi 6. The RAX120 is located near the middle of the 2nd floor. If there were ethernet or coax wiring on each floor, I would be using a different setup and equipment.
So far the RAX120 has been working well (no disconnects) and generally full speed except for the first floor where speed appears reduced about 65% from max (probably due to additional concrete block).
I do see an anamoly where my AX capable iPhone seems to prefer the 2.4GHz signal at night on the 3rd floor whereas it connects to the 5GHz signal during the day in the same area.
michail71
Jul 25, 2020Apprentice
LOL on the prefers 2.4. Most devices seem to blindly grab 2.4 when they see a stronger SNNR. With WiFi 6 it isn't as bad, but not optimal. I've got my desktop and router within 10 feet of each other and they will still go to 2.4 without a bit of configuring and "forget this" on my part.
I could sware I did port 1 only on the XB6 only and it still failed.
I've replaced all of my desktop clients now with Intel AX200 cards. They will outperform the direct ethernet connection but I'm suffering from random failures on all systems now. They can be easily bounded by an on/off of the wifi connection. But it only happens when connected to the RAX in ax mode. I think these failures are realted to the cards and perhaps not 100% the RAX.
If I could combine the best of the XB6 and RAX, it would be an amazing device. Netgear needs to get their act together on a few things.
- michail71Jul 27, 2020Apprentice
It's going back to Best Buy today!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I have that odd relieved feeling one gets when breaking off a bad relationship.
- worldturningJul 27, 2020Star
michail71 wrote:It's going back to Best Buy today!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I have that odd relieved feeling one gets when breaking off a bad relationship.
I feel for you.
I had an Orbi setup when it first came out and it worked flawlessly. Subsequent forced firmware updates made it unusable for the household with continuing satellite disconnects about 6 months later.
It's when I decided to wire the house and go for a prosumer setup. Working flawlessly ever since.
Yeah, I would but I'm renting and the runs wouldn't be easy in the house. Otherwise I'd go for a CAT6A or CAT8 setup.
When the RAX worked I could get faster speeds from the WiFi than I could wired directly to it. It was just blazing fast as could be untill it decided to drop 5GHz. Which seems to be about 3 to 15 times per day. The PCs on WiFi 6 would get the sudden slowdown, all randomly, which we could reset at the adapter quickly. Then all 5GHz connections would crash at once 1 or 2 times per day. The 2.4 GHz band seemed okay.
I think anyone running a single SSID may not notice these problems as much as this is a good 2.4 GHz AP. But I refuse to run fixed based systems on 2.4 GHz with excellent signal strength available. It may be why it works for some people. Neatgear may be masking the issue on 5 GHz that way?
I had a similar experience with an Orbi mesh system a cople years ago. It just prooved to be too unstable.
michail71 wrote:... I've replaced all of my desktop clients now with Intel AX200 cards. They will outperform the direct ethernet connection but I'm suffering from random failures on all systems now...
A wired connection is the best way to connect devices when possible.
Going further, using separate vlans for ioT, guest and main in some form is also additionally preferred. One can get really complicated here too with vpn and intervlan routing, etc.
It is why I use a different setup in my main residence (40+ devices) and have everything connected via wire where possible and enough AP's to cover those that need wireless.
