poison3000
Feb 18, 2023Aspirant
The AX1800: R6700AXS vs RAX10
Hi All,
I purchased Nighthawk AX1800 (RAX10). I love it !! signal is good and connected 26 devices all of them working great ! BUT ...
while I was searching through amazon I received a recommendation for AX1800: R6700AXS but cheaper by 35 USD with 1 year subscription for ARMOR.
So, I quickly fetched both specs to compare ... they are both identical ! specs and design wise ... I cant tell what is the difference .. should I return the RAX10 and get R6700AXS ?
https://www.netgear.com/home/wifi/routers/r6700ax/
https://www.netgear.com/home/wifi/routers/rax10/
- microchip8MasterKeep the RAX10. No point in swapping it if it's identical
- poison3000Aspirant
Hi All,
So I purchased 3 routers, based on best users reviews and compared all of them:
> D-Link EXO|AX AX5400 (DIR-X5460-US)
> TP-Link Archer AX3000 (AX53)
Nighthawk won the game. the signal was good all over the house, TP was the worst as devices where loosing the signal occasionally.
TP link has a really nice software (web interface) and app ... I liked it more than the Nighthawk. D-link has a great signal, mediocre software ...
some feature I was missing from the RAX10 such as USB, LED control, parental control.
what i noticed that devices connected to the 2.4Ghz has slow connection, up to 20 Mbps ... is there a better Netgear model that can get me faster connection on 2.4GHz ? or better generally on the same price ?
Also, what is the max number of devices can be connected to it ?
Not really related to the router so much as the WiFi technology standard involved.
How many clients can you connect wirelessly to a NETGEAR router? | Answer | NETGEAR Support
and
How many devices can my Orbi system support? | Answer | NETGEAR Support
