Jun83
May 20, 2021Follower
The RAX80 is powered off.
Hello, everyone. My RAX80 went out of power. Suddenly the power goes out and the LED doesn't light up either. On the RAX80, only the sound of "Tik Tik Tik" sounds very quiet. The warranty period ...
May 20, 2021Guru - Experienced User
got an old power supply sitting around you could try?
Make sure it has the same exact voltage and polarity. It can have more amperage.
Did you try the olf factory reset option?
Or if its out of warranty and you're a bit electrically handly, you could open it up and trace the power a ways to see if something simple is bad.
