duckware
Jan 17, 2020Prodigy
There are NO Netgear routers that are "Wi-Fi 6 Certified"
https://www.wi-fi.org/product-finder-results?sort_by=certified&sort_order=desc&categories=6&capabilities=17
blue13x
Jan 17, 2020Tutor
This has me worried. Been looking into the RAX200. I hope they are not basically beta products and they later on release V2 version that does adhere to the final wifi 6 specs.
- blue13xJan 17, 2020Tutor
After looking into the website, it shows that the broadcom BCM94908R43684AX chip is wifi 6 certified, and the rax80 and rax200 use it I think.
- duckwareJan 17, 2020Prodigy
Yes, in general every chipset will absolutely support Wi-Fi 6. But the worry is that Netgear's firmware is not up to par with others and will not implement some critical feature. And even if Netgear has the feature, we won't know if it works properly, or interoperates with others.
Being "Wi-Fi 6 Certified" is a stamp of approval (that is rather blatantly missing on Netgear's 802.11ax offerings).
Asus has an 802.11ax router that prominently displays the Wi-Fi 6 Certified logo.
And I'm personally considering the Netgear RAX200 and the Asus rog Rapture AX 11000. Might go with the asus in that case, eventhough the netgear does look better.
The Broadcom BCM94908R43684AX is an actual "reference design" router (NOT a chip) -- which given the name, we assume is using the BCM43684 chip (4x4 802.11ax Wi-Fi Residential Access Point Chip).
And this is exactly why being "certified" is so important. Everyone assumes that Netgear can create something unique (maybe using the reference design as a base) that works -- but until Netgear can actually get their routers "certified", we are left wondering -- is there something in Netgear AX routers that do not work, or does everything work properly?
Netgear, please get your routers "Wi-Fi 6 Certified" so we know for sure.
- digitsnbitsJan 17, 2020Apprentice
Please read the post directly above your last plastic, your answer is there.
