duckware
Jan 17, 2020Prodigy
There are NO Netgear routers that are "Wi-Fi 6 Certified"
https://www.wi-fi.org/product-finder-results?sort_by=certified&sort_order=desc&categories=6&capabilities=17
blue13x
Jan 17, 2020Tutor
After looking into the website, it shows that the broadcom BCM94908R43684AX chip is wifi 6 certified, and the rax80 and rax200 use it I think.
duckware
Jan 17, 2020Prodigy
The Broadcom BCM94908R43684AX is an actual "reference design" router (NOT a chip) -- which given the name, we assume is using the BCM43684 chip (4x4 802.11ax Wi-Fi Residential Access Point Chip).
And this is exactly why being "certified" is so important. Everyone assumes that Netgear can create something unique (maybe using the reference design as a base) that works -- but until Netgear can actually get their routers "certified", we are left wondering -- is there something in Netgear AX routers that do not work, or does everything work properly?
Netgear, please get your routers "Wi-Fi 6 Certified" so we know for sure.
- digitsnbitsJan 17, 2020Apprentice
Please read the post directly above your last plastic, your answer is there.
- DDRAGONApr 14, 2020AspirantThe RAX 80 and RAX200 have chips that support OFDMA up and down. The RAX 120 ONLY supports down because physically in the chip used, it’s only capable of down.
The RAX120 currently supports WPA3 whilst the others don’t. BelieBe it is meant to be done in a future update. Somewhere I think WPA3 was a requirement.
Some support 160Mhz native and others do a 80+80Mhz. 160Mhz is a requirement for certification too I believe.
The WiFi 6 certification requires a series of core and optional requirements. Part of the core requirements is Up and Down OFDMA. that rules out the RAX120 - hence I returned it.
There are other considerations such as WPA3, 160Mhz etc.
The RAX 80/200 don’t do WPA3 yet. orbi RKB85X Doesn’t do WPA3 or 160Mhz
So it’s abit of a mess because it seems everywhere you look, there are bits of firmware updates required before they can attempt to certify - as long as the hardware supports it (which arguably rules out RAX120 completely).
https://www.smallnetbuilder.com/wireless/wireless-features/33221-what-s-missing-from-your-wi-fi-6-router-ofdma- psychopomp123Apr 14, 2020Luminary
The RAX200 now supports WPA3 on the latest firmware (1.0.2.8)
https://kb.netgear.com/000061780/RAX200-Firmware-Version-1-0-2-8
