baileyj0611
May 29, 2020Tutor
This RAX80 Is DRIVING ME NUTS
ALRIGHT.......First of all, the speeds of this thing are great, and the coverage is great - However, the interface is SEVERLY lacking - It's very amateur and I don't think tthis router should be ANYT...
Christian_R
Jun 03, 2020NETGEAR Employee Retired
Hi baileyj0611,
May you follow the article below to update the firmware manually. You may also try updating the firmware using the Nighthawk app.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Christian
baileyj0611
Jun 04, 2020Tutor
man i've done this a trillion times, I'm tired of this router.
About to go back to Asus.
- Christian_RJun 05, 2020NETGEAR Employee Retired
baileyj0611 - Send me a private message with your contact info and serial number. I'll see if support can reach out for further investigation.
Christian
- baileyj0611Jun 05, 2020Tutor
I finally got it working....
I do NOT understand WHY you MUST use routerlogin.net instead of the IP addres of the router to do a firmware, that seems asinine to me.
Anyway, i'm running on .88 and things seem to be much better - I'm able to use te USB side of things finally.
thanks.
