baileyj0611
May 29, 2020Tutor
This RAX80 Is DRIVING ME NUTS
ALRIGHT.......First of all, the speeds of this thing are great, and the coverage is great - However, the interface is SEVERLY lacking - It's very amateur and I don't think tthis router should be ANYT...
baileyj0611
Jun 04, 2020Tutor
man i've done this a trillion times, I'm tired of this router.
About to go back to Asus.
Christian_R
Jun 05, 2020NETGEAR Employee Retired
baileyj0611 - Send me a private message with your contact info and serial number. I'll see if support can reach out for further investigation.
Christian
- baileyj0611Jun 05, 2020Tutor
I finally got it working....
I do NOT understand WHY you MUST use routerlogin.net instead of the IP addres of the router to do a firmware, that seems asinine to me.
Anyway, i'm running on .88 and things seem to be much better - I'm able to use te USB side of things finally.
thanks.
