TotalTirpitz
Mar 10, 2023Aspirant
Throttle Bandwidth
Model Version: Essentials WiFi 6 (WAX204) NETGEAR WiFi 6 AX1800 Dual Band Wireless Access Point (WAX204) Firmware: V1.0.2.4 OS: Windows 10 Environment: Home (3 Users) So the Xbox on my n...
microchip8
Mar 10, 2023Master
You cannot manually set a max/fixed bandwidth per device on NETGEAR firmware. QoS is as best as you can get
A fixed/reserved IP does not have influence on bandwidth, unless you use some tool to set bandwidth for a specific IP, which can't be done on NG firmware.
- TotalTirpitzMar 10, 2023Aspirant
So I'd need 3rd party software to limit bandwidth for this. I have to express the internet just stops for everyone when the Xbox starts downloading. And there's gotta be something before pulling the cable out.
- microchip8Mar 10, 2023MasterWell, I'm not sure if this is possible since I never use QoS, but if you can, set the QoS priority to lowest for the Xbox.
've already done that; it has the lowest priority on the network. But it overwrites it somehow.
