Bollax
Oct 02, 2024Aspirant
Through Speed
Hi All Little issue with my router. My through speed when connected to the router is only 193Mbps, yet when i plug the ethernet direct to my pc, i get 920Mbps. Hope some one has some ideas pl...
Kitsap
Oct 02, 2024Master
Bollax wrote:Hi All
Hope some one has some ideas please>
Thanks
Mark
Additional information needed for clarity:
What is the full model number of your router? Look on the nameplate on the device.
What is the full brand name and model number of your modem/ONT connected upstream of your router? Look on the nameplate on the device.
When your say your throughput when connected to the router, I presume you are talking about a Wi-Fi connection?
If yes, what band are you connected to? The 2.4 GHz band or the 5 GHz band?
What device, brand name and model number, are you connected with when you measure your throughput?
What application are you using to measure throughput? Recommend using the Ookla stand alone application that does not use a web address or web browser. Available from the playstores.
Bollax
Hi there
The router (data plate uploaded) is connected to the modem (data plate uploaded) via a Cat8 cable. Yes I’m measuring internet speed using Ookla. I figured no point I’m measuring the WiFi till the hardwired connection is sorted.
