Bollax
Oct 02, 2024Aspirant
Through Speed
Hi All Little issue with my router. My through speed when connected to the router is only 193Mbps, yet when i plug the ethernet direct to my pc, i get 920Mbps. Hope some one has some ideas pl...
Kitsap
Oct 02, 2024Master
Bollax wrote:Hi All
Hope some one has some ideas please>
Thanks
Mark
Additional information needed for clarity:
What is the full model number of your router? Look on the nameplate on the device.
What is the full brand name and model number of your modem/ONT connected upstream of your router? Look on the nameplate on the device.
When your say your throughput when connected to the router, I presume you are talking about a Wi-Fi connection?
If yes, what band are you connected to? The 2.4 GHz band or the 5 GHz band?
What device, brand name and model number, are you connected with when you measure your throughput?
What application are you using to measure throughput? Recommend using the Ookla stand alone application that does not use a web address or web browser. Available from the playstores.
Bollax
Modem pic
- KitsapOct 02, 2024Master
Your Sagemcom Model F3896LG-VMB is a combination modem/router. Specifically, how it is configured is critical to the configuration and functionality of your R8000 Wi-Fi router.
Are the throughput problems you are experiencing a new situation or are you just now configuring this network?
Your R8000 router is in a cascade connection downstream from a combination modem/router. This results in a situation called double NAT which can cause lots of problems. See here for reference: https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad.
You need to find out how your Sagemcom device is configured and then decide on how you want to configure your R8000. You may have to find a manual for instructions on your Sagemcom device.
If your Sagemcom device has a bridge mode that effectively disables the router, that would most likely be the best option to pursue.
If your Sagemcom device does not have a bridge mode, you will need to configure your R8000 as an access point. For reference see here: https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
- BollaxOct 05, 2024Aspirant
HI Kitsap
I tried the AP route, that improved it to 430Mbps. i will look at the option of bridging the Sagemcom and let you know how it goes.
This is a new phenomenon, that said, i never achieved the 900+Mbps with the direct connection but used to get around 740Mbps
- KitsapOct 05, 2024Master
Bollax wrote:HI Kitsap
Thanks for the update.
The 430 Mbps you reference, was that direct connected via Ethernet or over Wi-Fi?
Testing conducted using the Ookla stand alone application? On what device?
