stanfrench
May 15, 2022Luminary
Time Machine does not recognize USB drives connected to RAX200
I have been using the Nighthawk RAX200 router for slightly more than a year now. I had attached a Western Digital 2TB USB drive to the USB port of the RAX200 for use in Time Machine back ups to my iM...
stanfrench
The firmware I'm running is V1.0.6.138_1.0.76. I haven't tried a factory reset or firmware downgrade yet as I'm in the beginning stages of troubleshooting.
stanfrench
FYI, the former path that was recognized by Time Machine was: "afp://RAX200._afpovertcp._tcp.local"
This no longer works. I tried "smb://readyshare" which allows the USB drives to be recognized by Finder, but Time Machine does not.
Is there another path name that would allow Time Machine to be recognized? Any other settings I can adjust in the router? I really don't want to reset or downgrade the firmware unless I can be assured that it works.
- plemansMay 15, 2022Guru - Experienced User
Not sure as I'm not a mac/time machine guy so not sure its use/settings.
- stanfrenchMay 15, 2022Luminary
Thanks. I just checked the firmware releases for the RAX200 and the last one was released on April 22. My Time Machine stopped working on April 23 (date of last back-up). I think we can conclude it is somehow related to the latest firmware.
I will first try a factory reset with the current firmware and if that doesn't work, downgrade to the previous version and see what happens. I'll leave another post here with those results soon.
good luck!
