stanfrench
May 15, 2022Luminary
Time Machine does not recognize USB drives connected to RAX200
I have been using the Nighthawk RAX200 router for slightly more than a year now. I had attached a Western Digital 2TB USB drive to the USB port of the RAX200 for use in Time Machine back ups to my iM...
May 15, 2022Guru - Experienced User
Not sure as I'm not a mac/time machine guy so not sure its use/settings.
stanfrench
Thanks. I just checked the firmware releases for the RAX200 and the last one was released on April 22. My Time Machine stopped working on April 23 (date of last back-up). I think we can conclude it is somehow related to the latest firmware.
I will first try a factory reset with the current firmware and if that doesn't work, downgrade to the previous version and see what happens. I'll leave another post here with those results soon.
- plemansMay 15, 2022Guru - Experienced User
good luck!
- stanfrenchMay 15, 2022Luminary
Good news, bad news. The good news is that I am now able to use Time Machine again. The bad news is that it will only work under the previous firmware version issues in September, 2021. The latest version released on April 22, 2022 has removed the recognition of the AFP path that is necessary for Time Machine to recognize that a drive is present.
So for all you Mac users out there who want to use the two USB 3.0 ports on the RAX200 to back up your iMac or Macbook using Time Machine, you'll have to downgrade to V1.0.5.132_1.0.69 and forever keep to that version. Then you can use the path "afp://RAX200._afpovertp._tcp.local" to connect to the server. After that, Time Machine will recognize all USB drives connected to the RAX200 router. Unfortunately, you cannot get any important security updates after that. For me. the risk of data loss is the greater of two evils.
Like quite a few other frustrated Mac users who have commented here, I just don't understand how Netgear can issue an "upgraded" firmware that removes critical functionality. Does anyone check? Or maybe there just isn't enough of us to matter. In any case, I won't forget this when the time comes to upgrade to a new router. And you can bet it won't be a Netgear product.
Thank you Plemans (especially) for pointing me in the right direction during the troubleshooting. At least now I can use Apple's back-up system.
- DarrenMMay 19, 2022Sr. NETGEAR Moderator
I have checked with engineering and Time Machine Backup was removed in FW v1.0.6.138 and the patch notes will be edited to show this.
Thanks
DarrenM
