jstevens
May 20, 2022Aspirant
Time Machine fails with RAX80-V1.0.6.138_1.0.76
Time Machine use to work just fine with FM V1.0.5.126_1.0.65. After upgrading, Time Machine looks for the backup disk but returns the error message: Backup Disk Not Available. Try backing up again ...
Hadrien500
Jul 09, 2022Aspirant
The update also made my RAX80 unusable. Factory reset required... Time machine no longer works for me..
Jul 11, 2022Guru - Experienced User
Hadrien500 Time machine support was pulled from a lot of devices (couldn't find the post that a mod mentioned it) because there's a significant security risk with it. If you want to keep support, you have to stay on an old version and risk those security risks.
- Andy4711Sep 17, 2022GuideOk, now I’ll replace my RAX80 router by a product from another company.
Sine I purchased this POS there were always troubles with updates.
I’ll never buy anything from this company in the future.
