WaterDragon
Apr 04, 2020Aspirant
Time Machine Not Working on RAX120
I have not been able to get Time Machine working with my Mac and the RAX120. I am running Catalina (10.15.4). If I follow the instructions in the User's Guide starting on page 121 (Back Up Mac Comp...
WaterDragon
Apr 05, 2020Aspirant
Any tips on connecting to the router to even view a remotely connected USB drive? I haven’t even been able to do that. The router actually appears in Finder as a remote windows machine, but I haven’t been able to log in.
racsoboom
May 04, 2020Aspirant
same problems, it keeps saying connection failed when i try and connect, let alone find the USB to do timemachine backup
did you find a solution???
thx
- WaterDragonMay 04, 2020Aspirant
No, I have not found a solution yet. It seems like time machine and USB hard drives were not vetted with the latest version of Mac OS. It's clearly not a Netgear priority, because it still does not work after nearly a year since this product was introduced. I'm chalking it up to bad firmware on the router, essentially not being compatible with the latest Mac OS.
- racsoboomMay 05, 2020AspirantActually when i go to System Preferences, Network. Then click Advanced.
Under the TCP/IP tab i selected ‘Automatically’ from the ‘Configure IPv6’ tab and went OK. Apply. And restarted. Now it works...
