LegendarySage
Sep 04, 2022Tutor
Time Synchronization failed on Windows PC using RAX120 with AT&T's 5268ac router
Hi all, I'm using my ISP's 5268ac router which is bridged/port forwarding everything to my RAX120 router (AT&T doesn't allow other routers as the default modem). Everything is working fine on my...
- Sep 04, 2022
LegendarySage wrote:Hi all,
I'm using my ISP's 5268ac router which is bridged/port forwarding everything to my RAX120 router (AT&T doesn't allow other routers as the default modem). Everything is working fine on my network except for the time/date sync on Windows. My RAX120 router's NTP settings work fine and is able to get the time. The NTP settings on my ISP's router is working fine as well, so I'm puzzled as to why my computer can't sync with the time server. When I plug into the ISP's router directly, the time sync works on my Windows 11 PC. That is a workaround for now, but it's really annoying to have to do. I'm not sure what to do. Any help would be greatly appreciated!
Recommend you check the Windows settings on your PC first.
With the PC connected to your LAN and you are logged in with administrative credentials, go to Settings -> Network & Internet -> Ethernet and verify your network profile is Private. If not, change it to Private.
Now go to Settings -> Time & Language -> Date & Time and confirm your Region, Time Zone and automatic settings are correct. In that same window, scroll down and manually click on the Sync Now button. Look for error messages if it is not successful.
See attached.
Kitsap
Sep 04, 2022Master
See attached.
LegendarySage
Sep 08, 2022Tutor
Thanks for the suggestions. I modified my settings so that my Ethernet was Private. I then went to the Time and Date, and tried syncing but it failed again using time.windows.com. However, I went to change my source time server to time.nist.gov, and it worked! I selected it by going to Time & language, I clicked on Additional Clocks, Internet Time, and then change settings. So I guess there's still an issue with time.windows.com, but I don't really care where I get the time from, as long as it's accurate. So thanks for the help!
- KitsapSep 08, 2022Master
Good to hear. For future reference, there are good NTP servers at pool.ntp.org.
- LegendarySageOct 22, 2022Tutor
I'm having an issue where I can't seem to sync my time with any world clock using NTP. I have the same setup as posted here in this thread: Solved: Re: Time Synchronization failed on Windows PC usin... - NETGEAR Communities. The solution worked for me the first time I tried it and the clock sync'd correctly. Every time after that though, it fails again, even when the network is set to private. Here's my original question and set up along with the solution that only worked one time :P.
I'm using my ISP's 5268ac router which is bridged/port forwarding everything to my RAX120 router (AT&T doesn't allow other routers as the default modem). Everything is working fine on my network except for the time/date sync on Windows. My RAX120 router's NTP settings work fine and is able to get the time. The NTP settings on my ISP's router is working fine as well, so I'm puzzled as to why my computer can't sync with the time server. When I plug into the ISP's router directly, the time sync works on my Windows 11 PC. That is a workaround for now, but it's really annoying to have to do. I'm not sure what to do. Any help would be greatly appreciated!One time Solution:
