carloslijeron
Feb 07, 2024Tutor
Today I'm unable to access the dashboard and I get access denied
I have the same exact issue. Last night accessing 192.168.1.1 was fine to manage all my smart devices (50+), including smart lights and switches. Today I'm unable to access the dashboard and I get...
michaelkenward
Feb 07, 2024Guru - Experienced User
carloslijeron wrote:
Today I'm unable to access the dashboard and I get access denied. Resetting the router means 3+ hours of work to join and label all my smart devices. This is unacceptable. Netgear, this needs a fix, please.
Looks like something has gone wrong at your end. There are various reasons why people can't get into their routers.
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
and this:
If you cannot login to your router | Answer | NETGEAR Support
Did you create a backup of your settings?
If you want help, and not just to rant, which you are perfectly entitled to do, start your own conversation. If you do, it helps if you include the information that Netgear suggests in its header.
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
That is there for a good reason.
