Rcavaretti
Feb 21, 2021Follower
Total watts consumed
No where in specs can I find total watts consumed by either the base or satellites. Come on, for an appliance that's on 24/7, it's good to know electrical usage. If I physically had one in front of ...
Feb 21, 2021Guru - Experienced User
Doing the math would be fairly simple as I'm sure you know. But that wouldn't give you realistic expectations of average power.
My RAX200 has a 60 watt power supply (3.16amp x 19v) . But when I was measuring it, it was regularly 15-20 watt unless I put a significant load on it.
And my load on it wouldn't be the same as yours.
so to get a realistic avarage, you'd need one and a kill-a-watt setup to measure your average.
