MeMarco
May 04, 2025Aspirant
TP Link toggle: TL-WN725N does not connect to Netgear Nighthawk RAX120
Dear Community I have a challenge and I do not understand what the issue could be. Hope one of you can help me. The situation is the following - I have an RAX120 Netgear Router - I have ...
- May 11, 2025
Thank you for taking the time to answer. In the mean time I have found the (simple) answer. The toggle from TP Link only works wiht WPA (and not WPA2) ,so I had to change my security settings that is all..in the end :-)
May 08, 2025Guru - Experienced User
Something to discuss with TP-Link.
