MeMarco's avatar
MeMarco
TP Link toggle: TL-WN725N does not connect to Netgear Nighthawk RAX120
Dear Community   I have a challenge and I do not understand what the issue could be. Hope one of you can help me.   The situation is the following   - I have an RAX120 Netgear Router - I have ...
  • MeMarco's avatar
    May 11, 2025
    Thank you for taking the time to answer. In the mean time I have found the (simple) answer. The toggle from TP Link only works wiht WPA (and not WPA2) ,so I had to change my security settings that is all..in the end :-)
