pjd813
Jun 20, 2022Guide
Tri-Band vs. Dual-Band allocation?
How are resources allocated with a WiFi 6E Tri-Band router Versus a dual band WiFi 6 router? If a WiFi 6E router is installed yet the only devices around use WiFi 6 is the third band simply a wasted ...
Jun 20, 2022Guru - Experienced User
What model router do you have?
If you don't have any 6E supporting devices that use 6Ghz, then the 6Ghz wifi radio is not being used. Could be turned OFF.
