pjd813
Jun 20, 2022Guide
Tri-Band vs. Dual-Band allocation?
How are resources allocated with a WiFi 6E Tri-Band router Versus a dual band WiFi 6 router? If a WiFi 6E router is installed yet the only devices around use WiFi 6 is the third band simply a wasted ...
Jun 22, 2022Guru - Experienced User
the RAX120 is a pretty solid device. Problem is, you're reading on the forums. the forums are where people come with issues so if you search, you'll find issues with every device netgear has. If you read the reviews on the RAX120 from review sites and places like amazon, they're pretty solid. But there's always a few devices (or people) who've got issues.
So I'd try it out first before condemning it.
pjd813
Jun 22, 2022Guide
Yup. You bet. I need to see for myself. My question was just to satisfy my curiosity as to what your experiences were. Given that reviews can have a large number of people that are venting, I find it curious that the reviews for the Tri-band model on Amazon are consistently better overall. That’s not a scientific comparison by any means and I will just wait and see.
- FURRYe38Jun 22, 2022Guru - Experienced User
And if you get something from Amazon and it doesn't work out for you, you can send it back. Usually 15-30 days is what Amazon offers and if anything appears bad from the unit, be sure to use the return time frame.
