pjd813
Jun 20, 2022Guide
Tri-Band vs. Dual-Band allocation?
How are resources allocated with a WiFi 6E Tri-Band router Versus a dual band WiFi 6 router? If a WiFi 6E router is installed yet the only devices around use WiFi 6 is the third band simply a wasted ...
pjd813
Jun 22, 2022Guide
Yup. You bet. I need to see for myself. My question was just to satisfy my curiosity as to what your experiences were. Given that reviews can have a large number of people that are venting, I find it curious that the reviews for the Tri-band model on Amazon are consistently better overall. That’s not a scientific comparison by any means and I will just wait and see.
Jun 22, 2022Guru - Experienced User
And if you get something from Amazon and it doesn't work out for you, you can send it back. Usually 15-30 days is what Amazon offers and if anything appears bad from the unit, be sure to use the return time frame.
