philipco's avatar
philipco
Follower
Jul 12, 2022
Tri band wifi 6e. Can I link 3 of these together in an Ethernet bridge mode
Options are 3 and eventually more nighthawk wifi 6e routers linked as Ethernet bridge devices
or move completely to nest devices
  • michaelkenward's avatar
    michaelkenward
    Sadly, that message means nothing to me.
    Perhaps you could explain what your problem is, if you have one, and tell us which Netgear devices you are using.
  • plemans's avatar
    Are you trying to link 3x RAXE500's/RAXE300's together?
    Are you trying to use an orbi?
    What exactly are you trying to do?
    the Orbi RBKE963 uses a router plus + 2x satellites with quad band (1x 2.4ghz, 2x 5ghz, 1x 6ghz) setup
